Carbon Deposits
California
Does anyone know or recommend a fuel additive that cleans carbon deposits from the piston/combustion chamber?
Thanks in advance!
OTC solutions are:
Redline SI-1
Techron Concentrate
Gumout Regane
Lucas Upper Cylinder Lube
Marvel Mystery Oil
Seafoam
B-12 Chemtool
Special Purchases(Ordering or a shop/distro visit)
BG44K
Fuel Power
I may have missed a few....or ten
I’ve had better luck with a couple treatments of the B-12 Chemtool “Total Combustion System Cleaning Kit” then I have with many, many in-tank treatments. I’ve almost decided that the in-tank cleaners can’t really clean combustion chamber deposits with any efficiency. I think they do well on valves and injectors, where the cleaner is in more direct contact with the deposits. It’s hard to imagine how the in-tank cleaners, in the small dosages that are used, can really attack combustion chamber deposits.
Here’s a post I made about the B-12 kit: http://theoildrop.server101.com/cgi/ultimatebb.cgi?ubb=get_topic;f=5;t=004870;p=1
And, no, I don’t have any affiliation with B-12.
I still haven’t tried water. I broke an engine with water sometime in the early 80’s. I have not had the nerve to try it again.
Oh, almost forgot, the old standard for cleaning combustion chamber deposits:
The Italian Tune-up.
Kang,
I saw that B-12 Chemtool “Total Combustion System Cleaning Kit” on the closeout table of AdvanceAuto Parts a few weeks back.
I was wonderring how good this stuff works ?
I did the seafoam throught the brake line. Ok, But i feel the deep creep spraying into and throught the TB is the best.
See:
What do you guys think of BG44K?
Apparently BMW approves of it.
Do you use it like Seafoam or Chemtool?
www.bgprod.com/products/fuelair.html
Here's the link.
And, IIRC, Chemtool > Seafoam.
What about DIY stuff like acetone, toluene, xylene, paint/lacquer thinners, etc?
Valvoline synpower fuel system cleaner is pretty good. You can also try the maxlife fuel system cleaner, its identical to the synpower and half the price.
