Originally Posted by slacktide_bitog
Originally Posted by Huie83
Another option, Look for an older Toyota Sienna. I purchased a 06 sienna 4-5 years ago with 70K miles on it for ~$9 or $10K.
Not saying you have to go that old, you can find a 2011+ with low miles in your price range. I went older because I like the 3.3 motor vs the 3.5 in the newer ones. The 3.3 is easier to work on and run forever.
I gave it to my ex last year but its sitting around 120K miles now. Did the timing belt, front sway bar links and a trans service at 100K before I handed it over. Just normal maintenance the rest of it's life. Did I mention they are really easy to work on if you need to
Maybe he can get a 4-cylinder Sienna in that price range. They only made it for a couple years, but the 4-cylinder will be MUCH easier to work on than a transverse V6
Even though the transverse V6 is inherently a bad design, Toyota's are even worse
A 4 cylinder minivan sounds absolutely awful to drive. Can't speak for the others, but the Grand Caravan with the v6 has more than enough power to move out of its own way.
