Originally Posted By: mdocod
Originally Posted By: Benson96
I have a 2005 Saturn ion that pulls hard to the left when I apply the brakes. The car also veers left while driving at normal speed, even after two alignments done at a local shop in town. Both times the alignment tested as bad toe in the front, so they readjusted it and it would be fine for a few days then veer to the left again. Any ides for either??
Almost everyone is saying brakes, and I disagree with this based on the FULL set of information given. If it were brakes, then your alignment would "stick." On the other hand, a worn out ball joint, control arm bushing, or wheel bearing can ALL cause the behavior you have described as well as cause the alignment to appear "different" each time it is pulled onto the alignment machine. Furthermore, the description of the car "veering" left without any brake application also points to a worn out suspension component.
There is no way for seized caliper slides to cause the car to suffer from the inability to "hold" an alignment.
Yup I like this too. After doing rear LCA bushings on its cousin the HHR (and hearing that 'they all do that') I'd look there.
A $7 infared thermometer from harbor freight will give you amazingly accurate readings of your brake balance, which, if close between front rotor temps, will indicate a steering/ suspension fault.
