Originally Posted By: i_hate_autofraud
On late model GMs be careful when disconnecting battery:
You have to let the "Retained Accessory Power" (RAP) time out or the GM Onstar thinks power was interrupted by a car accident and activates it's own batteries that can't be turned off, they run dead and OnStar thereafter likely won't work in a collision.
This means: ignition key out, open the hood, close all doors, wait 3 minutes then take off the Neg battery cable. However, be sure to loosen the Neg clamp then cleanly remove the cable in one action. Accidentally allowing a reconnection restarts RAP timeout. Wrap the Neg cable connector in a rag, etc, so it can't make accidental contact. There's usually not a lot of room to stuff a cable once yanked off.
Nice to know eh?
Not true on the Onstar part. Yes, Onstar does have, depending on the generation and vehicle make/model, capacitors or a battery that holds a charge long enough to allow it to do it's thing. However, Onstar is NOT activated by power disconnects. It MUST see data from crash sensors (and other sensors) to activate. Disconnecting your battery while in your garage or driveway is fine and nothing will happen. I know this because I work with Onstar engineers every day and have first hand experience on these "mystery" onstar modules.
