Carbs, with all their component parts and required fine tolerances were a manufacturing problem. The TBI eliminated so much of that. It was easier to manage software calibrations than mechanical complexity.Been too long since I looked at any of this stuff...
On a carb, at idle or off idle, isn't the fuel going in after the throttle blade? The boosters above the plate are in action for large openings, right?
I have to ask as the one time I looked down at a running TBI setup, I realized that it was squirting right at the plate, and basically turning back into liquid gas. Maybe that was a poorly running setup (probably was, it was quite old) but the picture has stuck with me since. Seems like TBI gets better fuel control but not necessarily better mixing.
On grasswaymotorsports(?) there was a poster who claimed to be at GM back in the day; he stated that the only reason they went to TBI over Quadrajet was because of NOx. The carb was better on all other fronts. I can't validate that claim but mentioning for completeness--TBI was a speedbump as port injection was always better. TBI was just cheaper and easier to changeover from a carb setup.
Instead of building and managing the production control of dozens (sometimes hundreds!) of variations of a carb model you were building and installing one basic injector unit.
Same thing happened with automatic transmissions. Instead of manufacturing dozens of different valve body configurations with specific springs and valves and orifices, you have a basic hardware set and manage the electronic calibrations.
