Originally Posted By: gogozy
every Honda/Acura I know have ATF drain bolt that can be removed by square head (3/8") on the 3/8 ratchet, and i am sure 2000 Accord is the same. my experiences are these are very tight from factory. jack up the car high so you have clearances for ratchet, or extension bar to move/leverage.
I remember once told dealer ATF drain bolt was too tight, and ask them to just loosen it a bit and set it to factory spec when I was in for an oil change. they did and become reasonable tightness and easier.
Do not use the ratchet head by itself - use a short 3/8" extension. The ratchet head by itself is not long enough to completely fill the 3/8" drive square on the plug - so when you exert a lot of force, you will damage the plug.
The torque spec for most Honda ATF drain plugs is 36 ft-lbs, which is quite tight...and this is with a new crush washer. Snug is not tight enough. Also, if you re-use the crush washer, all bets are off.
