- Joined
- Nov 29, 2009
- Messages
- 10,258
So i'm under the impression that warner makes most of these pto clutches. I don't know if warner eletric is the same company, but Ferris wants $456.99 for this clutch Ferris part#5105090YP I've found 5218-388 as the warner part# for like $190.00 unless i'm missing something here. The pulley diameter seems the same, what else needs to match? I do believe the shaft is 1-1/8th" Wonder if I'd be better off just putting some good quality skf or timken bearings in it. I know bearings aren't what they used to be, but you get the idea.
