I am thinking of buying some Esso XD-3 0w30 instead of 0w40 for future use in my car. The car is a 1992 non-turbo VW 1.6 litre diesel with 391K km (244K miles).
The car runs fine on Rotella 0w40 and doesn't burn more than 1/3 litre per 5000 km. My goal is to run 12-15K km on synthetic oil while the factory spec is up to 12K km on the regular oil available back in 1992. The manual recommends 10w30 up to 15C (~60F) and 15w40 up to 30C (~85F). Well, nobody and I mean NOBODY uses single weight oil in Canada at any time, even when above 30C, so maybe the manual can be ignored a little for W30 oils too? It actually says that straight 30 can be run up to 30C so why not 10w30?
Is there a 15w40 or 0w40 oil out there that has an actual running temperature viscosity that is the same or below the actual running temperature viscosity of XD-3 0w30?
Why would I do this? Cheaper oil and slightly better mileage. If I get 1% better mileage I will notice it, my car is very consistant. I am also trying to make my car get the same mileage as it did when new. When I got the car I was getting 800-850 km per tank but I'm now up to 925km per 53 litres running winter fuel and winter tires. When new the car got about 1100 km on summer fuel and tires. The car has never had the engine, transmission, injectors, or fuel injector pump rebuilt.
Thanks for the input,
Steve
Steve
