Mixing oils,
The Jetta has a 504 spec I believe we use the blue 5w40 LiquidMoly
The Tiguan has 508 spec and we use the silver 0w20 Liquidmoly.
Now both engines are out of warranty. And i've been doing a good job of 4-5k miles per change. I've noticed the Tiguan is normally .5 quart low and many of on GTI forums say to ditch 0w20 for the 5w40 because its purely for MPG. The manual i believe, says we can use 1qt of 504 spec if need as top up and thats what i've been doing.
I'm thinking of trying to with a 50/50 mix of 5w40 and 0w20 to see if oil consumption goes away. Am i making like a weird blend of 2.5w30 or does it not work like that? I figured the people here have way more experience and knowledge VS the GTI forums.
