can viscosity at 40c or density be correlated with an oils W rating?
hey all! ive been looking around and i noticed that for example
castrol edge 5w30 has a slightly higher density but a lower kv40 vs something like mobil 1 0w30 afe which has a slightly lower density but a slighty higher kv40
i normally would have assumed that m1 afe 0w30 would have a lower kv40 but its higher then the castrol egde 5w30
so do any of these values correlate with an oil being a 0w vs a 5w? or is it just how it performs during the 0w vs 5w test ?
thx
Density relates mostly the base oil composition. PAO, which has very good cold flow properties is lighter in density than mineral oil. It's likely the Mobil 1 product contains more PAO than the Castrol.
Additives are also generally significantly denser than base oils.
Remember also that kinematic viscosity is absolute viscosity/density.
thx
No. The cold temp tests are conducted at temperatures well below 40C. Minus 5C to minus 40C
You didn’t get a good answer in this other thread of yours?
