Thanks for the posts, I had no clue this board was so active.
I'm at the end of a "top end" cleaning (GM additive in the tank) which results in some carbon & crap finding it's way to the oil so I'll be doing an OC soon, hence the post.
The Mobil 1 I use is Full Synthetic, yes?
The oil cooler is a great idea but not an option in my "stock" class - it would bump me into a class that allows lot's more mods than I currently have.
As I understand the history of the Vette the oil cooler was dropped when GM switched the oil recommendation to M1 Full Synthetic as it's supposed to handle the higher temps & dropping the cooler dropped wgt.of the car.
Water temps are 215 to 230, in normal crusing oil runs about the same or maybe 5 or 10 deg. higher. Only on race days (with some redline runs - 1st & 2nd gear) does it get to 250 - 300 range. Those water temps are considered good/normal for this car. Some guys will try to get the LT engines to run cooler but most of the "experts" I trust say that's not necessarily a good thing to run this engine too cold. The optimum target temp for oil for good life/performance seems to be at 240 deg F
My race club is SCCA San Diego region, cruise/wax club is North Coast Vettes.
I'm on extended warranty so need to stick close to factory/dealer recommendations so I'll have to stick with Mobil 1. I know the other's are "approved" and meet oem spec etc. It's just easier to show a receipt for M1 and not have to "educate" a service writer at the dealership.
It's seems I won't go wrong with a Mobil 1 multi that goes to x- 40 so I'll look fo that. Also is that 0w30R a "Race" oil that is ok to use on the street.
That also might be a good choice as I don't change oil specifically for race day vs. street. This is autox, not track or wheel to wheel racing so the cars tend to be street driven to the event (although we do have some that come on trailers)
Again thanks if you follow up re: this extra info
