Quoting myself from another thread with a few tweaks here:
Mixing oils isn't "optimal" because the odds of you improving something are infinitesimally low but negatively impacting some aspect of the chemistry, quite probable. It could be a reduction in low temperature performance (most common), an increase in Noack, throw off the FM balance...etc. Lots of things to "go wrong" which is why oils are fully formulated products and not Jebediah with a butter churn and some raw ingredients tossing this stuff together in a shed.
That said, unless you actually put the mix, and the products you mixed individually through the testing sequences, you really have no idea what has changed from the performance of each of those constituents alone. It's not something Joe Average is going to be able to determine from sight/smell/taste/feel or from a UOA and the odds of it having any easily discerned impact on longevity are low. Rings coking up, varnish build-up...etc, these things don't happen overnight or even over the course of a couple (normal) OCI's.
In the case of being frugal and using up surplus product, while I generally don't recommend mixing as a regular practice, what the OP is considering doing is quite reasonable.
