- Joined
- Jul 22, 2023
- Messages
- 147
The curve is shaped that way because the oil pump is in pressure relief above 800 rpm, but isn't in pressure relief below 500 rpm. This sharp knee-point in the curve is where pressure relief starts occurring.But if you look at the Z06 RPM vs OP graph, the curve can't be anywhere near a straight line and go through close to zero P at zero RPM. Same with Fig 9 in post 46. That's why I left that 0 to 500 RPM segment out of the x-axis. The pump flow vs P between zero RPM at idle isn't on the same trend as it is above idle. If I would have included the 0 to 500 RPM section of the x-axis, there's no way that curve could intersect zero without changing course way beyond it's current trendline path towards zero.
I highly doubt the pump is in pressure relief when the PRV is set to crack open at 70 PSI. How could the pump be in pressure relief at 800 PSI with hot oil. A flow of 4 GPM isn't enough oil flow to create 70+ PSI on the oiling system/pump output to make the PRV crack open.The curve is shaped that way because the oil pump is in pressure relief above 800 rpm, but isn't in pressure relief below 500 rpm. This sharp knee-point in the curve is where pressure relief starts occurring.
Here are some flow curves from Melling for some oil pumps for GM V-8's. These flow curves match the pressure curves from your Z06 quite well. Your oil pressure-rpm curve is shaped the way it is primarily because it's similar to the oil pump's flow-rpm curve.
Bearing self-pumping and factors that affect flow-dP linearity will have an effect as well, but they're all very minor relative to the effect that the pump's flow rate has on oil pressure.
Don't know where that table came from with the low PRV settings, but it doesn't align at all with the info in this Melling video. I'll call Melling tomorrow and see it they can clarify what the real story is.The two Melling pumps from the figure above have PRV settings of only 43 psi, which is higher than the OEM setting. Others are rated at only 20 psi or 33 psi. These GM V-8 engines are almost always operating with oil pump outlet pressures higher than the PRV setting, typically even at idle.
On engines like this, the oil pressure gradually increasing to ~double the PRV setting is by design. If the PRV had too little restriction, the oil pressure would be too low for the bearings at high rpm.
That part of the curve is linear, but the curve as a whole from zero rpm is not. This is true regardless of what the shape of the curve from 0-500 rpm actually looks like. There has to be a knee-point there even if we can't see the exact details of it. At high rpm, the flow could be levelling off with the Melling pumps due to pump slip and other factors.The curves also show a near linear flow output vs RPM as expected for a PD pump, and they also show a distinct knee-over at high PRM when the PRV starts to open. The stock pump behaves linear flow ouptput vs RPM too until it starts cavitation at high RPM.
The pump info came from here. There's a link to the application chart pdf if you scroll down.Don't know where that table came from with the low PRV settings, but it doesn't align at all with the info in this Melling video. I'll call Melling tomorrow and see it they can clarify what the real story is.
I plotted the OEM LS pump curve from the Melling graph, then also calculated what the flow vs RPM would be based on the 0.96 in^3 per revolution volume output spec for the standard OEM flow M295 with 100% pump efficiency (zero slip). Then applied an assumed 95% efficient pump at 500 RPM and the pump efficiency decreasing to 80% at 6500 RPM. The annotations are on the graphs.That part of the curve is linear, but the curve as a whole from zero rpm is not. This is true regardless of what the shape of the curve from 0-500 rpm actually looks like. There has to be a knee-point there even if we can't see the exact details of it. At high rpm, the flow could be levelling off with the Melling pumps due to pump slip and other factors.
The curve for an ideal PD pump is a straight line that intersects zero, where flow rate is directly proportional to pump speed. Flow rate per revolution for an ideal PD pump should be a constant. The OEM pump at 500 rpm is shown to flow 8.0 GPM / 1000 rpm, whereas at 6200 rpm it flows only 1.1 GPM / 1000 rpm, so nowhere close to an ideal PD pump.
I'd ask Melling about how they define the PRV pressure and whether it's consistent for everything they publish. It may not always be the initial opening pressure of the valve. I'm curious about the diameter and thickness of the gerotor as well, since 4 GPM is a lot of flow for 500 rpm and would require quite a large pump unless it's geared to spin faster than the crankshaft speed.
I can think of a few reasons why a oiling system might be designed this way.It just seems crazy that a PD pump would be over designed that much to put out so much more flow than what the engine is supplied. That would mean the pump is basically relieving most of it's available flow output in the higher RPM range - the flow difference between the blue and orange & gray lines gets crazy large near redline. The blue curve between 0 and 1000 RPM is out of bed with what the ideal output flow is based on the volume per rev spec.
Last time I called Melling, I was asking the guy about that Melling graph (I had that one saved a long time ago), but he couldn't tell me how the pumps were tested to generate that data. Maybe I can get someone that knows more about it. I'm going to ask if these pumps are basically in relief above ~1200 RPM as seen in my graph. That would be a crazy way to over design a PD in my opinion. I'm sure the pump rotates at the same RPM as the crankshaft, but I'll ask to make sure to verify if my orange and gray lines are accurate.
The older GM LSx series of engines (like in the C5 Z06s) don't have any hydraulic devices like VVT components or chain tensions, and don't have piston squirters ... they are basically simple "old school" engines. Piston squirters came along with the LS7. And the valve train doesn't need some crazy high oil flow volume to stay lubricated. They have hydraulic lifters in the valve train, and that's all. So I can see why the oil pumps are relatively low flow, with the stock pump max flow only being around 7 GPM at redline. Melling higher flow pumps are mainly to keep the oil from cavitating in the pump, like the OEM pumps can do near redline.I can think of a few reasons why a oiling system might be designed this way.
An engine will require a certain minimum oil pressure regardless of engine rpm, for hydraulic devices like VVT components or chain tensions. The figure below provides a good example of oil pressure requirements of an engine, with minimum required pressures in blue, and excessive pressure/flow shown in the yellow areas. On this Toyota engine, minimum acceptable main gallery pressure at idle is said to be only 7 psi to ensure proper functioning of the VVT system. Main bearings were also said to be a limiting factor. I'm not sure if the GM engines would require higher minimum pressures. Is there something about pushrod valvetrains that would require high pressure or flow at idle?
See table and graph below for OP vs RPM and oil temperature - yes, the oil pressure doesn't decrease a whole bunch with oil temps.An advantage of the GM design is that oil pressure above idle rpm will not be very sensitive to changes in viscosity. When the oil gets very hot, oil pressure at the bearings will only be reduced by a small amount, which would help prevent cavitation and bearing failure. It should also reduce the effect of oil pressure drops from oil aeration. On a engine like a Subaru, oil pressure can quickly get marginal at high rpm when oil temperatures start to get extreme, since oil pressure will be almost directly proportional to viscosity when the pump isn't in pressure relief.
The LS engines that have DOD and other hydraulically controlled components require the higher flow version pumps to ensure they get enough flow. That's one thing Melling points out in their pump application info.Another advantage of the GM design is that since oil pressure isn't as sensitive to oil temperature, hydraulically activated oil jets can be better controlled to start opening at the desired rpm over a wider range of oil temperatures, instead being open even at idle when the oil is cold.
Here's some data I took to see how the OP changed as the oil warmed up. True that the idle OP didn't change much between cold and hot oil. The OP at 212F would have probably been 34 PSI if the revs were up to 950 RPM like when measured at cold idle RPM.Another advantage is that since the PRV setting is low, cold oil pressures will be lower. Cold oil pressures on Subarus can be in excess of 140 psi, and that's measured downstream of the filter and oil cooler. This requires designing oil passages, gaskets, seals, and oil filters to be able to handle these pressures.
I think the oil filter would have to be really clogged to have a major impacted on the oil flow and resulting OP. I used 5 different brands of oil filters on the Z06 and did some RPM vs OP checks and never saw any real difference in the curves, so a few PSI of flow dP difference between filters at high RPM wasn't noticed. But yes, if the filter was super restrictive, that could cut some flow to the engine as RPM increases since the PRV is already opened to some degree at low RPM, so that's one thing to note on these GM engines. Overall, for an "old school" PD oil pump design, they actually work pretty well as intended.The main downside of the GM design is a small reduction in engine power output and fuel efficiency. Another downside is that excessive restriction in the oiling system, like from a clogged oil filter, will result in significantly less oil flow and less pressure at the bearings.
I ran my k24 with redline 5w30 and the hths of 3.8. Luckily the earthdreams engine is a oil dilution monster and I feel it probably dropped some. I did top off but my guess is I would like to keep it around the 3.0 to 4.0 hths.i stepped a honda K24 from a 5w-20 with an average HTHS value of ~2.7cP to HPL's 5w-40 with a HTHS value of 4.248. so far the engine is much quieter and hasn't taken a hit to fuel economy (already have 1600 miles on the oil)
our accord is a 7th gen so luckily we don’t deal with that.I ran my k24 with redline 5w30 and the hths of 3.8. Luckily the earthdreams engine is an oil dilution monster and I feel it probably dropped some. I did top off but my guess is I would like to keep it around the 3.0 to 4.0 hths.
yeah yeah, rub it in. Salt in a open wound.our accord is a 7th gen so luckily we don’t deal with that.
she paid $800 for it at 120k miles. okay i’ll stopyeah yeah, rub it in. Salt in an open wound.
It's impossible to have it both ways. You may not notice a significant difference but the lower viscosity, lower HTHS oil absolutely gets better mpg. Conversely, those running lower HTHS might not notice a significant difference in wear ("I drove that car for 300k mi on 0w20 w/o issue") but rest assured a higher HTHS does give better wear protection.i stepped a honda K24 from a 5w-20 with an average HTHS value of ~2.7cP to HPL's 5w-40 with a HTHS value of 4.248. so far the engine is much quieter and hasn't taken a hit to fuel economy (already have 1600 miles on the oil)
hand calculated 27mpg hasn’t changed coming from PUP 5w-20It's impossible to have it both ways. You may not notice a significant difference but the lower viscosity, lower HTHS oil absolutely gets better mpg. Conversely, those running lower HTHS might not notice a significant difference in wear ("I drove that car for 300k mi on 0w20 w/o issue") but rest assured a higher HTHS does give better wear protection.
"My car lasted to 340K miles on 0w20 and my buddies to 340K miles on 5w40...yup, that means there's no wear difference"hand calculated 27mpg hasn’t changed coming from PUP 5w-20
just say you’re a thin oil guy. i’ll go with higher protection."My care lasted to 340K miles on 0w20 and my buddies to 340K miles on 5w40...yup, that means there's no wear difference"
Both are fallacies we commonly use to establish our points of view. But if there were no difference, lower viscosity oils would not exist - because that really is the only reason they are around. Billions of dollars and thousands of tests attest to this.
Furthest thing from the truth. I just know it can't be both ways, pretty simple really.just say you’re a thin oil guy. i’ll go with higher protection.
and i presented you with data. fuel economy has not changed. 27 MPG average. the woman gets on a highway and drives ~37 miles one way at 80mph twice a day.Furthest thing from the truth. I just know it can't be both ways, pretty simple really.
It could be the main bearings in these engines that are the limiting factor then. MOFT in the main bearings seems to be lowest at low rpm, which seems to be the opposite of rod bearings, which have lower MOFT at high rpm. Or it could be due to the other advantages discussed.The older GM LSx series of engines (like in the C5 Z06s) don't have any hydraulic devices like VVT components or chain tensions, and don't have piston squirters ... they are basically simple "old school" engines. Piston squirters came along with the LS7. And the valve train doesn't need some crazy high oil flow volume to stay lubricated. They have hydraulic lifters in the valve train, and that's all.
The Subaru oil pump is driven at crankshaft speed. It's got a lower flow per revolution than the GM pumps, but it has a higher output rating since it's flow rating is based on the pressure being lower than the 102 psi pressure relief. It will only start going into pressure relief at high rpm when the oil is thicker than ~12 cST. If you compare the dimensions of the gerotor in the table with that of a GM pump, I'm sure the Subaru pump is smaller.Speaking of the Subaru pumps, have you ever seen the oil pump output vs RPM curve - are they 1:1 driven off the crankshaft? And hows that compare to the RPM vs OP curve taken off a running engine like I did on the Z06? Pump RPM vs flow and engine RPM vs P curves won't look the same as discussed because of the journal bearing side leakage reducing the oiling system resistance with RPM. It sounds like the non-variable pumps on Subarus have a much higher PRV setting.
Yes, "data" ok.and i presented you with data. fuel economy has not changed. 27 MPG average. the woman gets on a highway and drives ~37 miles one way at 80mph twice a day.
