Originally Posted by ekpolk
Originally Posted by ZeeOSix
Your (and others have used) the strawman argument that you don't see thousands of dead cars on the road or in junk yards due to using xW-20 oil, and that guys get 250K+ miles on their vehicles using xW-20 oil. Fact is, did anyone actually determine if there was no wear difference in those engines compared to using a thicker oil in them over their lifetime? Like I've said many times, most engines will still run pretty good even if they are technically worn out per the service manual specs.
I forgot to address this. This would only be a strawman argument if it could be established that virtually all the cars that go to the yard, and having been fed 20wt oil, are in a more advanced state of wear than they would be be had they been fed 30wt oil or greater. That, I strongly suspect, can't be proven either way. I suspect, IMO, that there are cars of both descriptions, with or without "advanced" wear, but at the end of the day, that's essentially unknowable.
Continuing our foray into the terminology of argumentation,
your position is actually a "red herring". You're focusing on the unknowable state of the cars in the junkyard, while not addressing the fact that we've simply not seen the pattern of early engine failures (pre junkyard) that ought to exist by now, if 20wt wasn't performing well generally.
Except there are many enginering studies and controlled tests that have been performed to prove less engine wear results with increased viscosity (all other factors held constant) for the reasons mentioned throughout these discussions. Are there many official engineering studies showing otherwise. So that is better than proving it through "how many dead cars in the junkyard" statistics. At any rate, people using that argument are strawmanning and not ficused on actual engineering testing results under controlled conditions. You know, the stuff that results in "scary tables and graphs".
