Originally Posted by ekpolk
Another poster recently suggested that I go ahead and switch to a 30 wt oil now and start getting better protection... Based upon what???
He's right, based on the many posted up technical papers showing how increased viscosity inreases MOFT and typically the increased HTHS along with it, thereby decreasing wear to a certain degree.
There's a difference between better protection and adequate protection. 20 wt might be adequate for most benignly driven cars (and obviously not adequate in some cases for the benign), but it's not as good at protecting than a thicker oil, even in benign use cases.
No, he's not. You just can't assume that in every application, the engine will, or even can reach the point at which the oil film will compromise. And even if you did, then you'd have to look at how the other components of the oil, in that engine, protect when the film thickness is compromised. You say, "[t]here's a difference between better protection and adequate protection." Are you not assuming that in every case, the engine can and will pass the point of substantially compromised film thickness? How is that a supportable assumption? The computer controlling 1NZ-FXE (the 1.5L from my old Gen-2 Prius) held the maximum rpm to a pretty low 5000 (I have a ScanGauge-II compensating for the car's lack of a tach). The new 18 Prius has the slightly larger 1.8L 2ZR engine, and it appears to be limited to 5500 rpm. Those would hardly seem to be "banshee screaming" high-stress situations that might overstress the oil film. Or that would lead me to ignore what the OM says and substitute the opinions of my friends on BITOG.
And this brings me back to the question I've posed several times, and none of the "thicker is better" advocates have answered: "where are all the vehicles ruined by 20wt oils in the twenty-plus years that car makers have been specifying them?" Again, not the individual special cases, but the overall mass of cars that certainly would have accumulated by now, were the 20s not up to the task. There would be a mixed mass of failures, Accords, Tauruses, Camrys, Civics, all "dying" in mass as they all were damaged over the years by "inferior" 20wt oil. This just hasn't happened.
The thick oil guys are relying on theory not real world evidence. Scientist also support the theory of evolution but real world evidence says otherwise.
