Valvoline Synpower 10w30 SJ
First oil fill and drain after AutoRx and Castrol 5w30 for 600 miles
mixed highway and city driving over 4 months
in hot Montgomery AL weather
Towed a trailer for 200 miles
quote:
Customer Name: John Bula
>2001 Camry V6 Miles/Hours on Oil: 5990
>Total Miles/Hours: 16440
>Results Comment
>(ppm/%) (blank = normal)
>Wear
>Copper 2
>Iron 5
>Chromium 0
>Lead 11
>Aluminum 2
>Silicon 8 very low for being new Toyota
>Tin 0
>Additives
>Molybdenum 7
>Sodium 2
>Magnesium 302
>Zinc 822
>Potassium 0
>Phosphorus 612
>Calcium 1740
>Physical Properties
>Water negative
>Fuel negative
>Antifreeze negative
>Soot 15 7% solids
>Oxidation 27 13.5% low
>Nitration 99 50%,slight elevation,may need fuel treat
>Sulfur 0
>TBN 7
>vis@100 C 10.7 30w
>Final Comments: Normal results, great wear values for this oil. Toyota
>engine is working fine
>no sign of sludge issues aside from elevated Nox. 6000 miles on this oil if
>it is all climate SL oil
>shows very good results. Could extend to 7000 miles safely. Any questions ,
>comments, fire away.
>Terry
