Nuclear CAPEX is higher, OPEX is not. Most nuclear plants have extremely low operating costs.
No, it takes quite a while for things to go south and a whole lot of stars need to align for it to get that bad. Fukushima was a total LOCA (they had no pumps, and no power to run them if they did have them) and it still played out over several days.
Safety systems are redundantly redundant. You have multiple types, and each type has a backup. This is fundamental plant design, you make every effort to prevent a serious incident from happening, but if one does happen, there are numerous mitigation mechanisms to contain, slow, stop and control it.
An operator acquaintance of mine likes to refer to the CANDU as cold molasses. Everything happens in slow motion. It's a reactor that doesn't want to run, but once you do get it running, it doesn't keep you on your toes. When we lost a fuel channel at Pickering back in the 80's (a 2m long split in a pressure tube) they didn't even have to use the emergency shutdown system. That's the most "exciting" event that ever happened with our 20 units.
The purpose of the aforementioned safety systems is to ensure that it can't go very very badly. Fukushima was a total disaster, but nobody died, the contamination was reasonably contained, despite the Mk1 containment (1st generation), of which newer plants have seriously improved upon.
Of course people will bring up Chornobyl. A Soviet design with no containment designed to be fast and cheap to build with the bonus of producing weapons material, that's not in any way comparable to Western plants.
I've never heard of anybody getting sick as a result of working at a nuke plant either, regulation prohibits it. This unnecessary statement is nothing but fear porn.
They are the most highly regulated civilian work environments out there. You are scanned coming in and out of the plant, and going between zones. There is an incredible amount of oversight and the regulator can shut the plant down if there are violations. The background radiation level in many places around the world is higher than what most nuclear workers will ever see.
The difference between that and working at a wind or solar farm is that wind and solar don't pay well. Most of the jobs are transient "Carnie" jobs, and there are very few post-install positions. Nuke plants employ anywhere from hundreds up to thousands of people, depending on their size, and a nuclear operator can push up on $400-500,000/year in the supervisor roles.
A wind turbine (or solar farm) can (and have) start a forest fire, which happened up here during the construction of Nation Rise. We've had more people die from wind turbines than we have at the nuclear plants, and the nuke plants don't spontaneously combust, like we've had multiple wind turbines do this summer.
The most devastating power generating incident in history was the failure of a hydro-electric dam. The Banqaio dam failure in China (also Soviet, like Chornobyl) killed somewhere between 26,000 and 240,000 people.
And, when a Western reactor buggers up, it bricks itself (TMI). Unless there are some Western nuclear power plant failures that I've never heard of that caused the widespread death and contamination you are alluding to with all these examples?
No.
Spent fuel is highly active for the first few years. All the most active fission productions have insanely short half-lives, so these are the ones that are the most dangerous, but also burn off the quickest. This produces a significant amount of heat, which is why it cools in a pool for 5-10 years until it can be shuffled into a storage cask. The activity, and thus the danger of the fuel, has already fallen off a cliff at this point.
The storage casks are designed to last ~100 years. These are called "interim storage", as they are temporary.
In Finland, and everywhere else that's building a DGR, the SNF is then shuffled out of the casks, put into tubes, and then put into what's essentially a mine.
After ~500 years (shorter for certain fuel types like CANDU) the radioactive decay has reduced to the level of the ore that the fuel was originally made from. You can hold it in your hands. It is not "forever" dangerous.
Products like Cyanide, Arsenic, Mercury, which are also stored in deep geological repositories, ARE forever dangerous however, and have to be managed in perpetuity. Some of these chemicals are used to produce wind turbine and solar panel components.
https://www.bbc.com/future/article/20150402-the-worst-place-on-earth
That's nonsense. Nuclear produces the least amount of waste per unit power of any source out there and is the only one that is required to be responsible for its entire waste stream. A single wind turbine blade graveyard, full of adhesives and fibreglass, leaching directly into the soil, occupies an area larger than all the spent nuclear fuel produced by the US over the last 50 years, which can fit on a football field.
How about all the pollution from the coal being burned to produce the solar panels in China? These facilities have their own coal power plants. These externalities are never accounted for.
Nuclear fuel is also recyclable, like is done in France. This material can be even further utilized in breeder reactors and those with higher neutron economy like MSR's or alternative CANDU fuel cycles.
But, as noted above, the best thing about radwaste is that it gets progressively less dangerous over time, which is not the case for the waste products and chemicals used in the production of several of the other technologies being panned as less problematic. This is easy to do because they aren't responsible for their waste streams like the radwaste folks are.
Where has just an earthquake caused a problem? If you are going to say Fukushima, that wasn't the earthquake, that was the Tsunami, the plant, and all the other plants in Japan, weathered the quake just fine, like they had done in the past.
While Tepco created a massive cleanup problem for themselves, nobody died from the incident at the plant. Thousands died from the Tsunami, which devastated the area. The Tsunami created long-term repercussions for the area, the "grandfathering" regulation that permitted Tepco to avoid upgrading the seawall and relocating the backup generators, created long-term repercussions for the company.
Well, it has the lowest lifecycle emissions of any technology we have available (which includes decommissioning and SNF storage), and, besides hydro, is the only non-emitting source that can provide firm, reliable power to provide the necessary electricity for an electrified society if we truly wish to phase-out fossil fuels.
Its biggest detractor is high capital cost. There is also the issue of access to cooling water, but that's a problem for any Rankine Cycle plant.
