I bought 4 super-tech filters today and noticed something odd:
I bought two ST2s - direct replacements for Motorcraft FL-820-S (4.6/5.4 ford modular motors)
One of the ST2s has a bypass valve on the base plate of the filter (where it threads onto the oil filter adapter) ala FL-820-S while the other ST2 did not.
I noticed that the valve takes up almost 1/4 of the entire filter, reducing the filter media size.
I bought two ST16s (direct replacements for FL-300s or the smaller 5.0 oil filters designed for limited block clearance) and none had the bypass valve.
I have Wix equivalents at home and the two FL-300 replacements did not have the base plate valves.
The wix equivalents for the FL-820-S also did not, but they did have this weird "H" metal thing welded to the bottom (has a hole in the middle).
I've been using the filters w/o the valves on the base plate for over 2 years now and never noticed anything really different. Any ideas?
BTW I have an FL-1A and even tho the filter is huge, the valve on the base plate takes up a great deal of space reducing the filter media size. Unless of course there's media behind the valve but it can't filter anything cause there are no pass-holes?
