Nope, it has not.
With fleet vans running excellent at half a million miles, no noise, consumption, smoke, etc., I would have to say that there may be a point at which extra filtration is not cost effective.
Our engines now easily outlast the vehicle they are installed in. No bypass filtration (we ran them for DECADES), no pre-lubers. Just quality oil changed via the OLM.
Also, just because you pronounce your S2000 engine as perfect does not mean it has not experienced wear. Odds are if I disassembled it and mic'd the pieces I could find some deviation from factory spec. I guarantee you that coated bore has some wear!
There was a time when a bypass provided some measurable benefits. I suspect the ROI is no longer in the same place. But they are great fun to play with...
