LOL
Yes there seems to be lots!
FWIW, I took my dual remote, pictured on here, and took off the ends and filters. I then used my Ohaus gram/oz scale to measure how much force it takes to move the ball off it's seat to allow oil to flow around it. It is not a very strong spring. I measured 5.0 oz (give or take a few 10th oz) to move the ball enough to pass by oil...perhaps 0.020". Now, all around that would amount to enough oil not to starve an engine, all else being good.
In other words, you would have to have very very low oil pressure for oil to not impart some sort of pressure against the ball/spring affair. I would say 1 lb pressure would still move the ball and move oil, not much but move it.
The bypass filter is tighter and will naturally take a lot more pressure to move oil through it. Let's say for practicality, that your idling at 900 rpm and your idle PSI is around 20. I would suspect that the lions share of the oil is now going through the full flow and maybe just a trickle is going through the bypass. It's relative and proportional to each other. When there is plenty of pressure then the bypass will be able to function better and still the lions share is going to the full flow.
Now with my '96 Buick PA, it takes the 3980 filter or 3387A(standard OEM Spec.) I don't know about the Baldwin/Hasting, or Super-Tech (made by Champion, or others, but the WIX does not have any pressure relief for this filter. I translate that into "DON'T PLUG IT!!"
I've got that bypass sandwich adapter that the race car mechanic gave me. It has the relief poppet sort of valve on the upstream side tat was to take the oil to an oil cooler in the radiator on a Buick Regal, 3.8 L V-6 engine of GM. It even had hose that was steel that went to the radiator. Now the sandwich adapter was designed for oil bypass for oil coolers. In a cooler there is NO pressure obstruction, or little is this correct? So in essence (for cooler app.) MOST of the oil bypasses the full flow, goes to a cooler in the radiator, and then back to the sandwich to blend with the rest of the oil on the outside (that was not cooled and made it though the sandwich adapter orifice) to then be filtered by the full flow. THIS sandwich adapter from GM, by the way is all steel, not cast or machined aluminum.
There is way more pressure on the sandwich orifice than there is on the Amsoil dual-remote. I imagined that was because they really 'wanted' more of the oil to go around and come back in cooled a bit.
My take is that if you route the oil from the bypass to some other spot,like the oil fill cap,that you would have to drill an additional hole or completely remove the factory poppet valve and let more of the oil go though that opening, since it is for filtration and not cooling. I would believe that enough oil pressure would be available to a BP filter with that poppet removed AND going to a 0 pressure point that it would work well. When you use the sandwich as a point of return you are actually returning to a near same differential pressure point and I might see problems with that.
So, this is my view: Motor fires up. Oil pump moves oil through he oil filter housing and creates oil pressure of 45 lbs pushing oil right on through the FF filter and into the engine galleys, which can only take so much flow so flow is slowed but pressure is maintained. Let's keep the constant 45 PSI as the norm on this illustration. Now, you add a bypass with that little poppet knocked out. Engine starts, and builds up to 45 PSI. Oil moves through the full flow and into the galleys same as before, but oil can only move so fast (volume) though the engine and filter subsequently. Excess "volume" head from the sandwich to the bypass unit. It is now at 45 PSI Enough to make it effective. The oil moves through the filter media, but because of the finer and tighter filter media it only flows through at a much reduced rate. BECAUSE there is 0 pressure in the center of the filter (because you plumed to a oil cap, oil pan, etc) oil will move slowly to the least resistance, the center of the filter and finally out to the line to the oil filler cap.
With the poppet valve in place and if you route the oil from the BP filter BACK to the same sandwich, your oil is meeting resistance, as most of the oil is already backed up from the lower flow of going though the engine(adequate pressure) and competes with the oil that has already gone through the bypass poppet and on to the full flow outside -> inside, and then into the engine as demand.
My assessment, and I could be all wet
is to remove the poppet valve and route to a 0 pressure return, NOT back to the sandwich that already has pressure.
Long winded huh?
Long winded huh?
