I currently run a bypass coolant filter on my Ford F250 Diesel.
The instructions from the filter manufacturer, and from the diesel community in general are to change the filter when the filter starts to get plugged. This is easy to check by feeling the filter to see if it is much cooler than the radiator hoses, or to check for flow, which is also easy because the bypass filter outlet is into the degass bottle, which is clear.
So if it is OK to run a bypass coolant filter out to its full service life, is it OK to do the same for an oil bypass filter? Amsoil, Franz, Motorgaurd, etc., all have a recommended change interval, some longer than others.
The big question that I have is, why not run these oil bypass filters until they at least partiallly plug up? Do they stop filtering as efficiently after XX amount of miles?
