I have been running full synthetic oil Amsoil 0W-30 for about two years in my 99 Jeep TJ 2.5 lt . I am thinking about installing a dual oil filter system.
Stupid questions time ( please bear with me)
I am no where close to a mechanic, not even shade tree status. Would this system be hard to install and be leak free?
Does the Perma-Cool dual filter system work the same as the Amsoil system ?
If so, do I need a full flow filter first, and then a bypass filter?
Some people have told me they believe using a dual flow system is harder on the oil pump, will reduce oil circulation,and make the oil sending unit work improperly .
Is it ok to use the rubber oil lines , and will they hold up ?
Last question, could I install a T filling on the return from the dual filter unit so I could use a mechanical oil pressure gauge?
Thanks for the tollerance
