Buy advice? Low mileage BMW but infrequent oil changes
South Wales, UK
It's funny how in Europe BMW's are by most people considered to be very reliable. Yet over in the US generally seem to hate them. Do US BMW's get assembled differently to ours? :rolleyes:
United States
different servicing environment. american technicians put a higher value on their labor and skills, and it gets more extreme with less common cars\brands.
South Wales, UK
Not sure you can blame servicing. For the last 10 years most BMW's have done 20k or 2 years between servicing. Far less than they would if they were in the US.
United States
by servicing i mean any kind of post-warranty repairs. big labor rates (inflated hours) + big parts markup = $$$. this is where the bad reputation of these cars come from.
Mahzurrah!
I think it largely comes from second and (worse yet) third + hand owners who are unwilling or are ignorant as to how to properly take care of the cars, and they also expect to drive them well into high mileage with the ownership costs of a Ford Focus. That's bound to lead to unpleasant results, and of course those must be blamed on the vehicle and then trumpeted all over the internet. Everyone here is a "victim" ya know. :rolleyes:
In the US many of these cars are bought down the line by people who can barely afford to get into the car but they want the "status". My neighbor drives an older Cadillac Escalade and rents a large house in a neighborhood dominated by owners on their third house (read financially well established). I've seen that Caddy towed for being a few hours late on a payment at least two times now, maybe three. Same kind of owner, different make. I honestly feel bad for them, they just don't know any better.
KY
Exactly; it’s the people who buy BMWs to wear. They cut corners on servicing or neglect it entirely- then they whine and moan when their fashion accessory breaks down. And it’s not just BMWs; I remember a guy at my old indie shop asking if the tech would just replace the pads and rotors on one wheel of his 944 to save a few dollars.
And, as we often see in these threads, there are a lot of “experts”-most of whom have trouble even spelling “BMW”-who repeatedly regurgitate third-hand internet hearsay.
Atlanta,GA
US cars are sold with more standard options which creates more potential failure points.
Oil leaks from failed gaskets are common and expensive to replace. For example Oil Pan, Valve Cover, Oil Filter Housing gaskets are wear items to be replaced every 50k-100k miles.
Parts are expensive due to comparatively low volume of vehicles sold in the US and the fact that they must be shipped from Europe.
It's expensive to operate a repair shop in the US.
Now would you like to buy my 435i?. It's a 2015 with 59k miles on it. I've replaced the OFHG gasket, valve cover gasket, spark plugs, and had the automatic transmission serviced. I'll let it go for $16k (USD) but you'll have to ship it to the UK. ;)
I would be more worried about the rear subframe to chassis mounting points than the engine. These crack around the bolt holes and if left can cause significant floor pan damage.
get it into a specialist who knows them for a PPI as these cracks can be easily missed if you don’t know where to look. I’ve seen one car you could only see cracks with the subframe removed.
Same specialist should be able to advise on rod bearing issues.
Atlanta,GA
There's a reinforcement kit for that as well.
Yes, however I have seen the welds then crack after they have been fitted. BMW was putting new rear floor pans into them under warranty then adding a structural foam into the chassis legs! Just something for anyone wanting one of these cars to be aware of before purchase
KY, USA
I've got a '97 Ford with 41K miles. Up until 30K miles it got oil changes every 3K miles regardless of elapsed time. Since 30K I've changed the oil every 5K miles regardless of elapsed time so, it's a 24 year old car that's had 12 oil changes. I use 10w40 conventional oil in it. Looking through the oil filler cap at the valve train it's clean enough to eat off of. At least 95% of the time when I take it out it's going to be run long enough to get the oil up to full operating temperature so there's no problem with moisture. When it's not being driven it sits in the garage sometimes weeks/months at a time.
In the case of the BMW 6 oil changes in 40K miles would amount to an oil change interval of approximately 6500 miles on full synthetic. I see nothing there I'd be alarmed about.
