My 2002 Century drivers side window is not going down, thankfully it's stuck in the closed position.
It was working fine one day and the next day it just wouldn't open.
A couple of years ago it was getting sluggish in the cold months but I lubed everything thoroughly with silicone spray and it's been normal for at least a couple years then all of the sudden it stops without any sluggish warning.
I am not sure if this is a case of the common failed regulator or just a simple switch issue.
The driver's switches all still work for everything else and all the other windows work fine.
Regulator or switch?
