Browning Buckmark Camper problems
NJ
I have a Browning Buckmark Camper that I'm having trouble with. The problem happens with both of my magazines. The gun will shot a few round and then jam. I pull the trigger and nothing happens. The slide is jammed shut and it takes a good effort to pull the slide back. About 90% of the round ejects and it is in good shape and I will reload it and it fires fine. About 10% of the time, the round is bent, sometimes quite a lot.
The gun has about 500 rounds through it and I clean it after each trip to the range. Any ideas what to do to fix this issue?
Originally Posted By: Hokiefyd
Has the firing pin impacted the cartridge rim? Or does it seem like the slide or bolt is twisted and it's not hitting the cartridge?
Good question and unfortunately, I don't have any spend casings to look at. I'll go shoot it again in a week or two and see how the firing pin is impacting.
The two screws on top were snug but I tightened them up a tad. Don't want to strip them so I didn't go too crazy tightening them.
Seems to be a feeding or striker problem, would the extractor cause that? If I had stovepipes, I'd go after the extractor more.
Originally Posted By: Brian Barnhart
Does the problem exist with more than one type/brand of ammo?
Don't know. I only had one box of ammo with me. Some Winchester hollow points. Will try some other types of ammo next time after I check those screws to make sure I didn't mix them up.
Thanks for the help.
