Brighter / Whiter Headlight Bulbs
Are there any headlight bulbs that'll fit my Camry that are brighter or whiter than the standard bulbs. I'm looking for bulbs that'll just drop right in, not HID any of those fancy bulbs. Just something brighter/whiter than standard.
I believe the standard bulbs are:
  • H11
    Low Beam
  • 9005
    High Beam
I believe you can get 9005 and H11 in higher wattages, but also test for voltage drop. If you're not seeing alternator voltage at the bulb plug, that's a problem and will become a bigger problem with more wattage (=more amp draw = more resistance = more heat)
  • H11
    Low Beam
  • 9005
    High Beam
Most major manufacturers make brighter, whiter than factory bulbs. If the same incandescent tech, it runs the filament hotter to do so, which means substantially shorter lifespan, like maybe 1/8th the lifespan for 50% brighter.
How are the plastic headlamp housings themselves? If they're not crystal-clear, you'll be wasting good light output thru dim or discolored housings.
They're fairly new, look new, and the light units themselves are of good quality. Good point, though.
Forgot to add: how's the aim on the lights? If your housings are in good condition and you have decent bulbs, the last variable to check is for proper aim.
Also, if your low beams are glass projectors, you could look into some LED bulbs. There should be some pretty bright plug-n-play options available.
  • Like
Reactions: hrv
  • H11
    Low Beam
  • 9005
    High Beam
Philips Xtreme Vision H11 are brighter than most or all other H11 bulbs. No idea about 9005 bulbs.
As for whiter light, it may not be advantageous to you, depending on your eyes and age.
Headlights need to be aligned a bit, and that's on the ist to be done at the next OCI.
I don't believe my bulbs are projectors. I believe they were available on the higher trim level. My friend had a 2011 XLE and his headlights were different than my Camry's lights, which which is the basic LE model.
  • H11
    Low Beam
  • 9005
    High Beam
Wagner BriteLite - 9005BLX and H11BLX from Rockauto.
The SYLVANIA XtraVision ( Philips , Osram ) have bright white light to help clarify at night . They spread far off to the sides and quite far down the road . All depends on your headlights aim or if any adjustments are needed . The Xtreme Vision don't live as long as the XtraVison , know this from experience . If the bulbs have easy access , you may want to consider the Xtreme Vision . Another reason I go with the XtraVision is their lower price under $22 before tax . Let us know of your decision and the experience with those you choose .
@Shel_B
Consider using the standard, NON Long Life bulbs in those sizes. Long Life (LL) bulbs run a larger (thicker) filament that won’t get quite as hot, to prolong the lifespan. Using NON LL bulbs gives a tighter, more focused beam due to the thinner filament and yields a slightly hotter color temp. No frills.
How I would like to see the good old candle power regulations of the 50's and 60's return.
Nothing better than being blinded by super bright head lamp glare on a nice rainy night.
People with good night vision are very miserable with the lights on cars nowadays. Some of us have to use sunglasses for night driving because of it. Sorta reminds me of the cough cough good ole days of all the inconsiderate smokers in restaurants, and is why more restrictive laws happen. I sure hope the day comes normal incandescent brightness returns to head lights, and huge fines come to the bright ones. Sorry to be so issy pey on this.
I would go LED. Just don’t get the super bright ones. Whatever brightness/lumens they claim in their models, get the lowest one.
I’m pretty happy with the ones I have in my Grand Caravan, made a noticeable difference without blinding others on the road.
I'm not interested in LED, HDI, ABC, or XYZ. I'm just looking for a standard bulb that will provide a bit more light that fits with absolutely no modifications into the standard socket.
"Pretty happy" doesn't seem like much of an endorsement, although it's better than unhappy <s> "Very happy" would get my attention.
In my own experience I found exactly that. They just didn’t last as long as the stock bulbs. Also, I found that although the bulbs were whiter they did not necessarily light up more of the road ahead of the vehicle. I went back to conventional bulbs that came with the vehicles.
