Hey everyone,
I finally got the Integra running and driving properly, but I've had another issue that I've been meaning to get fixed. When my headlights or parking lights are on, the passenger side brake light does not work. It works when the headlights are off. The tail light (also the same bulb) does work when the lights are on, but goes off when the brakes are pressed instead of getting brighter like it's supposed to. Any ideas? I've already changed the bulb with a brand new bulb and it did the same thing. I also checked to make sure all of the other bulbs worked and all other bulbs on the vehicle are working properly. Would a faulty fuse cause just one brake light to stop working? I didn't see any corrosion in the connector for the bulb, either. The wires looked fine on the harness from what I could see. Any help would be greatly appreciated, but from the looks of things I'm most likely going to have to take it in for something that I thought should've been very simple...
