I have a 2000 Chevrolet Cavalier base sedan.
I recently rebuilt the drum brakes and after bleeding the system I noticed that the two outer brake lights weren't working. The third (deck) light worked as did the parking lights and turn signals/flashers.
I looked at the bulbs and replaced them although the parking lights indicated that the "dim" element worked and the turn signals indicated that the "bright" element worked. I've read that this could be caused by the BOOS (brake on/off switch) so I replaced that...no luck.
The sockets are getting a signal (14-16 ohm) from the BOOS although I'm not sure how strong it would need to be to light the bulb.
I'm fresh out of ideas.....
