Ran a log splitter for about 45 min, and cam melted / broke. Engine was way too hot. Why?
Cooling fins not blocked. Not over reving.
excessive valve lash/timing?Ran a log splitter for about 45 min, and cam melted / broke. Engine was way too hot. Why?
The hydraulic pump makes the splitter not so much the engine .That’s called “Run her till she blows”
A 190cc quantum sounds way underpowered for a log splitter. It was probably wide open on the governor the entire time.
if it specs and measures out the same I suppose you could. I think you should understand that you may have moved the weakest link to a more expensive part. My guess is B&S did this for cost, but there could be another reason.can I use the metal gear in an engine that had plastic?
