1A - Wrangler AT/S
1B - Wrangler AT( used truck - tires that came on it )
3 - Wrangler RT/S
4 - Wrangler HT
5 - Wrangler ST
6 - Wrangler HP
All you've done is to put the traction tires at the top of the list, and the highway tires at the bottom of the list.
While it does appear all I did was list them by type it goes past that. For instance the Wrangler ST's while FREAKIN HORRENDOUS were actually a better tire than the HP's I have now which are GOD AWFUL SCARY FREAKIN HORRENDOUS. If you read what I wrote about the GY tires in general you would see I mentioned all the Wranglers I have had, regardless of which model, had the problems I listed.
The ones at the top lasted a little longer and had slightly better traction overall but had a rougher ride. The ones at the bottom didn't last quite as long and were awful tractiuon wise but gave a slightly better ride. I place more value on tread life and wet/snow traction than ride comfort and noise but that is important as well.
When taken as a whole that is how I feel those tires stack up. If it makes you feel any better I can name a bunch of AS tires that eat up the AT GY's at the top of that list in all areas( Michelin LTX M/S, Firestone Destination LE, and Bridgestone Dueler H/L Alenza just to name 3 ). Only makes sense that the AT styles would be at the top and the AS at the bottom as I was comparing GY to GY. Compare GY to other brands and there would be a lot of AS tires above those GY AT's. All of them in that list flat out stunk!
All of these long winded explanations are nothing more than what I stated before. The traction tires are in the top of your list, the highway tires are at the bottom of your list. You keep restating the same stuff over and over again.
You don't listen and/or have poor reading comprehension skills then because it went way beyind that. What is your point anyway? How are you adding to this thread? All you are doing is being a tool. Lame.
