Brembo Calipers
I'm planning on doing a brake job in the near future. If needed, I'll replace the calipers. My first thought was to go with OEM parts, but somewhere I read about a fellow switching to Brembo calipers on his late-model Camry. The Brembo name has always equated to solid brake performance in my mind, but I really don't know much about them. So, my question is this: What benefits or advantages could I expect from using Brembo calipers on my Camry?
I'm sure they're not needed for the Camry and the type of driving I do, so I don't need to be told that, or that I'd be wasting my money or any such thing along those lines. I'm just curious to know what benefits and advantages can be derived from using these calipers. Thanks.
Brembo is a brand. Without knowing which model of caliper, how can anyone answer the question?
If I asked about getting more performance by changing to an HP computer, would you be able to answer?
I’ve got Brembos on both Mercedes and the R model.
Those particular four piston Brembo calipers work well.
But braking is more than just the caliper piston count. There is a matter of rotor size, swept area, and pad composition, among others.
I'm ignorant about such things. I don't know anything about models. But, there are Brembo replacements for the 2011 Camry. They come in several grades. How do they compare to the original calipers on the Camry and what benefits might be derived from using them?
As for your computer example, yeah, if I knew what you were using I could discuss to some degree the benefits and drawbacks of certain HP computers. So, using the 2011 Camry as the "known computer" there's a point from which to start. If one were familiar with the Brembo lineup, it seems reasonable that a comparison can be made ... for example, this model is lighter weight, this other model has more pistons, the third only handle special pads, etc.
I'm guessing the install for the Brembo calipers would involve some modification to fit. That's the rub. Having brembo calipers and pads would probably produce a better pedal feel, but why? Spend some money on aftermarket performance pads (do your research on them) if you have an itch you need to scratch.
My GT500 came with 6 piston Brembo calipers but I would think that for what Brembo calipers cost, you could upgrade your brakes for a fraction of the cost. I doubt Brembo makes calipers for a Camry but I'm sure that someone out there makes slotted rotors and better pads.
Brembo exclusively manufactures multi-piston fixed calipers, no sliding calipers at all.
So the question results 'does Shel benefit from fitting four or six piston fixed calipers?'.
And I'm pretty sure this question can easily be answered with a loud and clear NO.
Shel, forget it as quick as possible.
Are you confident Brembo even makes a caliper for your vehcile?
A quick look on RockAuto shows only single piston replacement available, and Brembo isn't listed (although I can't say they normally stock Brembo)? They have a Powerstop option, but again only single piston...it is painted red though ;-)
If you just want OE replacement, get the Raybestos Element3 all-new calipers :)
If you want something more fun and flashy, Powerstop reman calipers are painted red :D
I am confident that by switching to a fixed, multi-piston Brembo caliper you will gain great brake feel and modulation, as well as a larger selection of performance pads.
When my minivan needs brakes I will be ditching the wimpy stock stuff for Brembos.
