Greetings BITOGers,
I'm about to take delivery of a 2022 Yukon XL, and I wanted to ask your advice for break-in procedures. Starting out with what the manual says:
The vehicle does not need an elaborate break-in. But it will perform better in the long run if you follow these guidelines:
-Do not drive at any one constant speed, fast or slow, for the first 800 km (500 mi). Do not make full-throttle starts. Avoid downshifting to brake or slow the vehicle.
-Avoid making hard stops for the first 300 km (200 mi) or so. During this time the new brake linings are not yet broken in. Hard stops with new linings can mean premature wear and earlier replacement. Follow this breaking-in guideline every time you get new brake linings.
-Do not tow a trailer during break-in. See Trailer Towing 0 271 for the trailer towing capabilities of the vehicle and more information. Following break-in, engine speed and load can be gradually increased.
-Do not tow a trailer during the first 800 km (500 mi) of vehicle use to prevent damage to the engine, axle, or other parts.
. It is recommended to perform the first oil change before heavy towing.
. During the first 800 km (500 mi) of trailer towing, do not drive over 80 km/h (50 mph) and do not make starts at full throttle.
I'm planning on towing soon after picking up the vehicle ... however, 50 mph or less will be a significant challenge. We're talking a small 5x10 trailer with 4' tall sides. Recommendations on this? I'd like to tow highway speeds.
Most importantly, how soon would you recommend changing the oil? Planning on a 0w20 7.5k OCI, but should I do it sooner on the factory fill? It would seem sooner wouldn't be bad ... since they recommend a change before heavy towing.
Any other recommendations for breaking in a new V8?
Thanks!
