'99 Ford Explorer
Front Rotors: GD7084
Rear Rotors: GD7049
Front Pads: UD652
Rear Pads: UD667
The Good:
Noticeable difference in braking right off the bat, no vibration or noise issues. Doesn't dust wheels as much as OE pads
The Bad:
Build up of surface rust on rotor vents, noticeable after 2,600 miles. Vehicle operates in a dry environment, only moisture is sees is weekly washes of undercarriage and body. No impact on performance, but certainly an eyesore when the wheels are off.
'00 Mitsubishi Pajero
Front Pads: DP4954R
Rear Pads: DP6958
The Good:
Noticeable difference in braking.
The Bad:
Can squeal a bit, dusts more than OE pads but there is a payoff between that and better braking. Also, not much choice in rotors for this application; ended up going with DBA rotors instead.
2001 Mercury Grand Marquis
Front Pads: UD748
Rear Pads: UD690
The Good:
Perfect alternative to OE pad, noticeable difference in braking and less brake fade in comparison to OE. Dusts noticeably less than OE pads.
The Bad:
Tendency to squeal in stop and go traffic in high heat conditions.
Front Pads: DP31615C
Rear Pads: DP31615C
The Good:
Definitely a step above the Ultimax2 range; better braking, dusts about the same.
The Bad:
Doesn't last as long as the Ultimate2 under the same driving conditions, but there is obviously a trade off.
2005 GMC Envoy
Front Rotors: GD7212
Rear Rotors: GD7213
Front Pads: UD882
Rear Pads: UD883
Same good and bad as the Ford Explorer; including the rust issue with the rotor vents.
