Originally Posted By: BrandonVA
I think it's my rear drums but i'm not too sure.
Does the squeak happen when the vehicle is in motion AND when the vehicle is stopped and you pump the brake pedal?
If it happens even when the vehicle is stopped, then it's likely to be the shoes scraping against the backing plate. A bit of hi-temp grease in the appropriate locations will solve it. If you're not comfortable pulling your drums, get a garage to do it. Should be a cheap fix.
