Originally Posted By: Trav
+1 One of the most important steps. Cleaning the hub face, the back of the wheels and center hole so the wheel slides on easily is very important especially with aluminum wheels. A tight center can cause uneven tightening.
You can use a drill mounted wire wheel or what I finds works well on the flat wheel surface is a 5-6" round random orbit sander with 120-150 grit paper, it does a nice job,
just sit it on the back of the wheel nice and flat and run it, move it around slightly but do not move it off the center too much, you want it uniform.
Don't worry about pits you just want the junk off.
I never thought about what's in bold...thanks for the info and I will do this next time I swap my wheels.
