Originally Posted By: 1 FMF
Originally Posted By: doitmyself
Here's a different slant on the increase of brake pulsation in recent years:
"Pre-loaded wheel bearings have no end play to "absorb" hub and rotor run-out. Hence, almost 100% of any axial run-out of the hub and brake rotor are transmitted to the brake pads. This axial run-out or wobble in the rotor causes the brake pads to wear the rotor unevenly over time, producing two sections of the rotor, 180 degrees apart, where the rotor thickness becomes thinner than the other two sections. This difference in thickness is called Disk Thickness Variation or DTV."
From a site promoting the use of on car brake lathes:
http://www.rtitech.com/downloads/archive...0to%20know.doc.
They also recommend the need to turn brand new rotors on many cars due to "inherent" hub run out on cars. They obviously have an agenda here, but interesting none the less.
this seems a little incorrect, or at least confusing.
most front wheel hubs are complete sealed units these days, meaning if you have a wheel bearing going bad you have to buy a whole new hub for $300+ instead of just replacing the bearing and race yourself for $20. This is a manufacturing process to save cost at the manufacturing level, along with increasing bearing life- there is an optimal preload setting to any taper roller bearing which allows for maximum bearing life. timken has some nice writeups and a tech site regarding this:
http://www.timken.com/EN-US/solutions/au...nts/Vol6No3.pdf
http://www.timken.com/EN-US/solutions/automotive/aftermarket/heavyduty/techtips/Pages/default.aspx
this preload amount is controlled when the hub and bearing is assembled and because the bearing has preload, that results in no endplay, which in turn if the hub is manufactured correctly will have zero runout. So i do not understand what is meant by absorbing runout, the hub should turn true to begin with. If it doesn't, then that's the problem. The solution to that which i think it stupid is they turn the rotor when mounted on the hub on the car to fix the runout wobble problem- the correct course of action is replacing the wheel hub with one that turns with no runout.
I say all this because a friend bought rotors from summitt for his mitsubishi eclipse a few years ago, and summit had this shim kit which said install these shim under the rotor on the stud then measure runout on vehicle, and move shim until minimal runout is achieved. It was like they new the hubs on the eclipse were f'd, needless to say my friend said that's stupid, never used the shims, and had wicked brake pulsation from day 1.
1FMF:
Those are great articles from Timken. They make a great product (I am a discriminating, but happy, Timken customer). They have a reputation and a customer base to maintain.
I think you make some excellent points.
Someone who buys the bargain-basement hub assy and brake components is begging for trouble.
A properly adjusted hub set won't have any runout. The only geometric variation will be among suspension groups (wheel, hub, bearing, A-arm, strut, etc), found in the perpendicularity of the hub axis with respect to the plane of the brake pads (pads being oriented by the caliper, knuckle, and possible other suspension parts).
I have to surpress the gag reflex and lunge for the trash can whenever I hear somebody make a bearing or brake purchase decision based on price! Save that reasoning for something that doesn't have to keep you going in a straight line at 80mph! Or for something that doesn't have to keep you from totaling the Lexus in front of you in traffic!
DOne ranting for now. Maybe.
