Brake rotors - how much are you paying to machine them?
Well lets think about this...that is $70 to turn a pair of rotors. That is about 0.3-0.5 hours of labor depending on the shops labor rate. I'd say that is pretty good since it will probably take a half hour from start to finish for the rotors to get turned. Most shops will charge an hour minimum for small jobs.
That said...I'd just get a set of new rotors from RockAuto.
If you have a brake lathe, that's one thing. Otherwise ya gotta factor in the hassle of taking them somewhere, waiting/killing time, and returning to get them.
^^^Exactly. As cheap as new rotors are, getting them cut isn't worth the time. Also, where I live, rotors don't reliably last a second set of pads before they rot through from the inside out.
Are ATE rotors better? I know Zimmermanns are not always OE but I've always been happy with them. Curious if it's worth seeking out ATE over Zimmermanns in the future
If I can get ATE, I always go with them. I have Zimmerman now on the BMW front, on Tiguan ATE.
I used ATE regular rotors on the street and track. On this BMW, I had ATE doing 30k, street, and probably 15 track sessions (on original brakes before the upgrade). But, they are pricier than comparable Zimmerman. The reason why I went to Zimmerman for this BMW is that I upgraded to Brembo brakes from F30 335/340i, and the difference in rotor price (slotted and dimpled) was some $190.
