edyvw
$50 site donor 2026
ATE for me.BMW dealer or Zimmerman! Nothing else.
Fair enough - however, the machine and its maintenance aren't free. Neither is retail square footage. It's possible the math works.When it's being done at an auto parts store (O'Reilly still does them), the employees are already on the clock working and it's not like they stand next to the machine while it's operating. It's an automated machine. They do need to set each rotor up but once that's done, they hit the 'go' button and walk away.
The irony is, they also sell new rotors. Maybe the profit margin on turning them is higher than they get on parts.Fair enough - however, the machine and its maintenance aren't free. Neither is retail square footage. It's possible the math works.
I'll typically do it if the rotors measure above the scrap spec enough to safely cut them, or if it's going to be a farm/scrap/beat around vehicle for my friend. I charge $90/pair. I turned the fronts on my Silverado and they've done well but under moderate downhill braking they are starting to pulsate again. When it gets bad enough I'll toss them and replace with new.This is true, even for something like a third gen Ram 2500.
However most shops and semi-professionals are still (rightly) concerned about comebacks (and TIME of having to GO somewhere and RETURN from that somewhere) that new rotors are preferred. It's not about hiking the bill -- additional profit is negligible -- but rather doing it ONCE
If people want machined rotors I make it clear I make no promises. Problems tomorrow? Full boat time & materials to fix it. All new parts, I'll stand behind it and make it right.
That said, @Kennedy01 seems to turn 20 rotors a week and I'm guessing it works for him. Still, I won't bother.
Also true. I normally guesstimate how much it's gonna cost me per year to go with one or the other option for products life, and how much care and work is expected on my part.Maybe for a little common car, but get into bigger or more rare stuff and can be $400+ for a set of rotors
If you eventually go with new oem rotors get them cryo treated. Alot of scca drivers at least several years ago recommended it especially if it's a spec class that doesn't allow for upgraded, high performance rotors. I've been told that they last significantly longer.I've been quoted $35 USD to have each of my front brake rotors machined (turned). I detect a minor vibration under braking.
Total $70 + taxes. I haven't had someone turn my rotors in a long time because I've been replacing the rotors every time for my own cars.
This time, it's for my Dad's Lexus and it's the OEM rotors which have been good for 13 years (low mileage every year). I'm thinking that if I machine them, I'd get another 7 years. New OEM rotors would be expensive and new cheap ones would likely not last 7 more years until they warp.
It's just that I didn't remember machining rotors to have been so expensive, especially since there's not much work involved (I'm bringing the rotors to the shop as opposed to them having to put the car on a lift, remove the wheels, take off the calipers, and put them all back).
What have you all been paying? How did you find a good price?
Not worth it. Just get new rotors. Coated rotors are awesome![]()
Yup. I just checked to see how much name brand rotors cost at Rock Auto. For my wife's Outback, quality rotors from Power Stop, AC Delco, Centric, and even Brembo, can be had for about $40.When cheapo rotors came out, the material was junk. Nowadays RockAuto offers a great selection with good prices. I match those Geospec, or whatever, rotors with factory pads for a good solution.
I keep reading this and it couldn't be further from the truth.Most GM ones are so close to the minimum thickness when new,
I found exactly one O'Reilly's near me that still turns rotors, and a bunch of other locations that don't. Autozone and Advance apparently don't do it at all. And even at that one O'Reilly's, it's on a once-a-week schedule when the one older part-time guy is there. But he does a great job on everything I've brought him.
Agreed.I keep reading this and it couldn't be further from the truth.
With only a handful of exceptions, EVERY brake rotor produced in the last 50 years allows 2.0mm between new thickness and discard thickness. That can be consumed either by wear or by machining, or a combination of the two.
I can verify the Express/Savana 2500/3500 ones always seemed to be worn out when it was time for pads, and I've had several uncoated ones rust the fins enough to start falling apart. Did have a Ram rear set of rotors do it too, but the Fords have been pretty good. Coated rotors FTW every time, and there's already a set of Wagner coated ones here for my Express...Agreed.
I can't account for what @bullwinkle claims about GM rotors, but every set of aftermarket rotors that I have bought, measure right at specification - just like the OEM rotors.
I'll have to check on them. I still have Parts Plus Smyth Automotive w/2 machine stops still open in Milford & Pisgah OH-need to ask them if they can still do them.I found exactly one O'Reilly's near me that still turns rotors, and a bunch of other locations that don't. Autozone and Advance apparently don't do it at all. And even at that one O'Reilly's, it's on a once-a-week schedule when the one older part-time guy is there. But he does a great job on everything I've brought him.
