Brake pad shim blown out
Suburban Washington DC
Was doing a normal brake inspection on my 2017 Corolla iM. See this on the right front. I occasionally heard a weird snapping sound when driving but didn't think anything of it. Wonder if I can get just the shims alone? The pads and rotors look fairly new.
The 4 on the left have stainless steel on the outside, a coating on the inside facing the pad and are identical. The 4 on the right have the coating on the opposite side and 2 of them have the tabs in different locations.
Black ones first then stainless on the outside.
Not sure how that would work as 4 of the shims have the black on one side and the other 4 have it on the other side.
So I can have the black coating against the back of the pad with the first shim, and stainless on the other side so that the stainless of the second shim are together and then the black coating of that 2nd shim is against the caliper piston or ears.
Or I can have the stainless against the back of the pad with the first shim, and the black coating on the other side so that the black coating of the second shim are together and then the stainless of that 2nd shim is against the caliper piston or ears.
Intuition suggests the first scenario where there is the stainless between the two shims so they are free to move easier, but who knows.
Also, compare the position of the tab ears to the old ones you take off.
These are aftermarket pads so the Toyota shims aren't exactly the same and have only one on each pad.
The second scenario highlighted in red above is the correct orientation. The stainless side must always contact the piston(s) and floating caliper frame. The 3 small clip tabs on the pads force you to attach them in one direction...you must use two different shims on each pad and the outward facing shims must show stainless steel.
Thanks for the info. And those 4 clips should go on the bottom of the pads I assume?
^^^ Your photo shows correct placement of the inner shim on the brake pad.
I have two shims on the pad. Inner shim has stainless toward the back of the pad and outer shim has stainless facing up. Black coating between the two shims.
No, top of the pads.
Got it. On the leading edge as the rotor turns.
That Permatex silicone based lube is fine; however, you should remove, clean and lubricate the slide pins while the pads are out. I normally apply lube to the piston ring surface and the floating caliper frame only where it contacts the stainless steel shims. I don't apply any lube between the inner shim and the brake pad's backing plate. Don't apply lube between the shims since the black surface is a self lubricating graphite coating.
Did that. The pins had grease but it was more like glue it was so sticky. Removed all of it and used the Permatex. All back together now.
