You probably have naked cast iron caliper bracket dont forget to take the pad clips/shims or whatever they are called and clean the rust under it. Rust starts to lift there pinching the pad ears casing jams.
I had to file lots of popular brand pads here bosch, raybestosm and several others. Never had a problem with Akebono or EBC or Hawk fitment. And no, no filing after because it is useless the heat and friction will peel that off in a week. If you live in the rust belt you have to take a apart clean and relube the brakes once a year any way so clean it up once a year to keep it sliding.
[/QUOTE
While BITOG members in rust belt may "clean and lube" brakes yearly I doubt too many people bring their cars to a mechanic to have it done. And given the labor cost it might be cost effective to slap in new pads yearly when the brakes are "clean and lubed".
But as we know most people wait until they hear or feel a brake problem to have brakes serviced.
I've noticed the same thing. Very common for pads needing a little filing on the ears due to extra dried paint accumulating there during manufacturing. The ears is a very small contact area that should always have some small movements, so provided the brakes are being used regularly I doubt rust would ever build up to a point where it causes problems.I had to file lots of popular brand pads here bosch, raybestosm and several others. Never had a problem with Akebono or EBC or Hawk fitment. And no, no filing after because it is useless the heat and friction will peel that off in a week. If you live in the rust belt you have to take a apart clean and relube the brakes once a year any way so clean it up once a year to keep it sliding.
Thus worth getting high quality pads.Dried paint is not as bad as mfg. uses worn die and does not tumble the pads so they come out all jagged with raised lips and edges
A quick search on Amazon found only two products called Molly Lube and both are an aerosol dry lubricant. Is that what people use?Here is what Akebono sent me when I asked what they recommend for the ProAct pads. I went ahead and did that plus M77 between the shim and the pad because Nissan recommended that as well in the FSM. Worked fine. Those pads are so quiet anyway, I’m sure it didn’t matter what I did.
No it’s usually a silicone base with a ton of moly solids suspended. M77 assembly paste is a commonly recommended version. Sold under the DuPont, Honda or ACDelco brands.A quick search on Amazon found only two products called Molly Lube and both are an aerosol dry lubricant. Is that what people use?
I have some Dow M77 I put on under the SS clips.No it’s usually a silicone base with a ton of moly solids suspended. M77 assembly paste is a commonly recommended version. Sold under the DuPont, Honda or ACDelco brands.
“Suitable for lubrication points with low to moderate loads and low speeds, which are subjected to water and extreme temperatures. At temperatures above 230°C, the carrier volatilizes leaving virtually no residue, and the remaining dry sliding film itself takes over the lubrication up to +450°C; Suitable for lubricating parts consisting of materials that are not resistant to mineral oils; This product is used successfully on metal/metal combinations with frictional and contact surfaces, brake anchor plates and the brake pistons of disc brakes.”
That’s not the issue. I take my little Milwaukee angle grinder and clean the caliper bracket and then a thin layer of anti seize before I put the clips in. It’s the stupid design of the wear indicator clip. The more you grind the more the clip expands and pushes down the pad. It’s a design on the 19s on up but has never caused an issue. My wife’s 24 has the same design and has akebono pads from the factory. I went to clean them up yesterday since the cars coming up on a year old and nothing was gummed up, but I still lubed the slide pins even though it really wasn’t needed. The factory installs these pads dry, no lube on any part of the pad anywhere. Probably why everything was clean. I’ve found that a new pad (especially ebc) with their break in coating dusting, a little lube on the ears=glue.You probably have naked cast iron caliper bracket dont forget to take the pad clips/shims or whatever they are called and clean the rust under it. Rust starts to lift there pinching the pad ears casing jams.
Lube one side of vehicle and not the other. Check in a year or two and see which is better.I just serviced the pads and pins last night on our 2024. I’m trying to figure out which is the best way in Ohio. Nissan didn’t use lube anywhere except the slide pins and minus a little dry dirt, the pads and hardware were rust free and still sliding well. I just used some brake cleaner and a toothbrush on the hardware, and the slide pins were still quite lubricated. I did my 21 earlier this year that I lubed all contact points and the pads were darn near jammed from the silicone turning into an almost glue. I’m leaning towards nothing but the slide pins here in the north. Anyone who’s driven in salted slush can understand how mixing that with silicone would be a recipe for a frozen pad.
Absolutely correct with this statement. In the rare event I’ve had to file (ebc) is a rarity. I have a can of Por 15 caliper paint that I use to touch up where I have ground anything off. That paint is like a weld on anything you put it on. I did just lube a set of good year pads I put on my rogue but think I’ll be replacing them. I thought I liked them, but they squeaked yesterday lol. Any brake noise makes my wanna jump out of the car. Nissans Altima uses some stupid spring contraption on their front pads that I can’t figure out the purpose of that makes the fit tight regardless. It somehow works but I’m not a fan. Now my 18 rogue has the opposite that takes 4 hands to keep the pads in place to install the caliper over top of them.Lube one side of vehicle and not the other. Check in a year or two and see which is better.![]()
Maybe because I haven't used factory pads in forever, I do find some fit/move better than others. Using new stainless shims/mounts I had some pads that did NOT want to go in brand new due to paint or whatever on the tabs. Those had to get touched/filed. Now those no longer have a protective coating so unless you put something, rusts very quick.
