Originally Posted By: artificialist
Every time I have used DOT4, the system stayed cleaner, despite the fact that I'm told DOT4 absorbs more moisture.
Valvoline and Pennzoil make great DOT4 approved brake fluids.
Don't get duped into the hype of "Full synthetic brake fluid." DOT 3 and 4 brake fluid is a glycol ether, which must must be made synthetically.
So, I have read a lot here and other places about mixing brake fluid and most say NOT to mix.
My question is simple: I just purchased a bottle of Valvoline Synthetic DOT 3&4 brake fluid. It clearly states: "Mixes well with conventional fluids". Is it acceptable to mix the contents of this bottle with conventional DOT 3 brake fluid?
If not why?
If not why?
