That is what my local indie shop said. I believe him that it is just a wallet flushing.A mechanic at my local indie shop told me last week that a brake fluid change on a Honda is just a money grab by the dealer. I'm not sure I believe that.
I'd honestly question any mechanic that doesn't recommend periodic flushes, but that's me. Maybe he wants to sell more brake components....That is what my local indie shop said. I believe him that it is just a wallet flushing.
...or residual pressure valves on older cars, "G" valves on some cars, etc.So please explain to the listening audience how "Brownian motion" works through non-serviceable filters in ABS systems?
Preventing Damage to ABS Modulators During Brake Pad Replacement - Phoenix Systems
www.brakebleeder.com
We just changed the original fluid in my 2005 Silverado half ton, drum brakes in the rest. 3/4 bleeders came right out. 4th was seized so it will need a new $12 wheel cylinder on that side to get the last bit of fluid out. My mechanic says a fluid change in the reservoir will not make it all the way to the wheel cylinders. Just changing the reservoir fluid isn't going to do much in his opinion. He thinks it's a good idea to flush the fluid every 3-4 years, although they haven't been selling many flushes lately because they go by condition and some of the newer vehicles are staying clean quite a while. They don't try to sell a flush unless the fluid is black like mine was.So please explain to the listening audience how "Brownian motion" works through non-serviceable filters in ABS systems?
the pricing can be inflated yes. but the fluid is cheap and the procedure for diy easyThat is what my local indie shop said. I believe him that it is just a wallet flushing.
No.When you just replace part of the reservoir does that eventually cycle through the entire system?
No. Please read this:Could you take a shop vac and insert it in the top of the brake fluid tank and suck out pretty much most of the brake fluid and then refill with new fluid ?
At that age it still likely had a lot of moisture in it, even if the fluid was still looking clean, so probably still a good idea to change it.Finally got around to changing brake fluid in my daily driver 2003 Toyota Camry. About 120,000 miles, owned since new. May have wasted my time as it looked clean as a whistle.
That possible, though not sure where the moisture would come from?At that age it still likely had a lot of moisture in it, even if the fluid was still looking clean, so probably still a good idea to change it.
It absorbs it from what I've heard. They have test strips you can use to check moisture content to help you determine if your fluid should be changed.That possible, though not sure where the moisture would come from?
Tight fitting lid on reservoir. Absorbs water from where? Have not seen a vented system on a new car in decades.It absorbs it from what I've heard. They have test strips you can use to check moisture content to help you determine if your fluid should be changed.
It absorbs it every time these guys take the cap off the MC reservoir to look in it. I never have...and never had issues with my vehicles' brakes.Tight fitting lid on reservoir. Absorbs water from where? Have not seen a vented system on a new car in decades.
through the sealing in the calipers actuallyTight fitting lid on reservoir. Absorbs water from where? Have not seen a vented system on a new car in decades.
And through the brake hoses.through the sealing in the calipers actually
3 year is initial fill.This is interesting to know and now makes sense why my VW's and Mercedes were all strictly 2 years - well minus the possible misprint in my '16 owners manual that gives you 3 years first go around then every 2 years after.
