On our Freightliner box trucks, the 19 inch U Bolts cannot maintain an adequate preload for more than 3 or 4 years. Not that the nuts are walking out. I use threadlocker on assembly. Here in the rust belt, the nuts become hard to turn after a few months and inpossible to turn after about 20 months unless heated red hot.
The U blots are stressed heavily when the truck box is fully loaded. Mainly the 1/2 in thick tie plates bend and perhaps the bolt stretches. The U bolt is threaded 5/8-18. The flat washer supplied witht he U bolt is not a Belleville washer. One side is perfectly flat while the other side is domed as seen in pic 3. The thickness fo the washer is the same at its ID and OD but the washer is thicker midway between ID and OD.. I don't see that this dome shape helps maintain preload.
Will split lock washers or Belleville washers help maintain preload? Can a split lock washer, flattened at least partly on tightening, maintain its spring tension and spring back to take up any slack that develops? Would Belleville (disc) washers be better?
Buyers Products includes split lock washers with their U bolt kits
https://www.buyersproducts.com/product/square-bend-u-bolt-kit-745
Amazon has Grade 8 split lock washers and they are not expensive
https://www.amazon.ca/gp/product/B000BD8M4M/ref=ox_sc_act_title_1?smid=A3DWYIK6Y9EEQB&psc=1
