NO.. even though the engine likely has a wideband o2 sensor, the HIGH load / high boost are likely mapped in to tables with only marginal capability to set coefficients through MAP, IAT, and RPM as the variable. And nothing compensated if you greatly improve airflow at high rpm / high boost. Your compensation would be only within the realm of "normal" airflow +/-where the wideband O2 operates. You would likely run LEAN(er) if the intake was truly effective. Wher you would be lucky was if the engine was tuned very rich and the CAI would move that back into a better place.Why would you think an Air Intake would void my warranty? Since I will disconnect the battery during install the computer will re-learn the air flow that comes with installing the air intake. No issue.
And I see you didnt respond to or understand hemholtz resonance setting up metering problems.
These CAI are designed to remove money from you wallet. That's it.
Plus I'm sure KIA says "any failures related to unauthorized bolt on performance parts will void warranty coverage"
Just like Subaru with the exploding REX
