Thanks but lots of folks here at BITOG are knowledgeable about a lot of things,like most mechanics (I'm to old to be called a tech and i like the term mechanic ) i knew hardly anything about grease,oil and even less about antifreeze other than you bought a jug of Prestone,peak or whatever (it was all the same at one time)and some distilled water,i learn something new every day here.
New replacement units are almost always MFI,on this engine its very easy to do.You need the unit like the one i posted from AA,a bracket and a gasket.Time is about an hour and a half.
No ECM flashing or other parts are needed,its a straight forward swap.
If you can change spark plugs and an alternator this job is within your capabilities.
As i said before this is really a beneficial upgrade and will safe you a ton of aggravation in the future.
The A/C
Any guesstimate on price would be wild speculation as it could be anything from a leaking schrader valve or line o ring to a compressor seal or evap core that may need the dash to come out to get at.
It may just be low on refrigerant over the years and the low pressure switch is keeping the compressor from turning on.
Take it to a good automotive A/C shop and get it diagnosed with an estimate.Expect to pay $75-100 for a decent estimate depending on your area.
Believe it or not the dealer maybe your best bet as every corner gas station with a service bay seems to have become A/C specialist with summer coming.
The A/C
