After looking around at a lot of vehicles, I came across this one when looking at a Liberty and a Toyota Matrix. Aesthetically, it is was the best one I was looking at. I'm a little concerned over the timing chain issues on the 4.0L, but when it started up from a cold start the engine is quiet. I found the window sticker and it came with the factory tow package and hitch, 4.10 axles, and LSD. Everything works on it, but there are a few minor issues. There's a front axle seal that needs changing, I might have an oil leak on the engine, still trying to figure that one out, the driver window motor needs changing, and there seems to be a rattle someplace. So far I changed the engine oil and air filter, front diff fluid, transfer case fluid, and did a few drain and fills of the PSF reservoir. I'll change the spark plugs, transmission fluid and filter, and rear diff fluid next.
