zorobabel
Thanks, seems like it will flow out the fill hole with the engine turned off: https://bobistheoilguy.com/forums/threads/did-i-over-fill-my-ford-6r80-transmission.338482/Probably
FTM was already suggested, but LEARN your noises now.
Good luck. I'd never willingly step into the 3V market again. It's a fool's errand and there are better options for equal money
You're kidding me? 4.5k is a steal; here in that Carolina's, I bet that would fetch twice that.Bought it at an auction over the weekend.
XLT EL trim, 190k miles, former state vehicle, some rust up top near the remnants of the antennas, some rust underneath the paint on bonnet (did Ford paint these outside in the rain?), some panels misaligned on the right side. Including pic with the good side. Only front chairs present, need to buy some chairs for the second row. Interior behind front seats is kind of beat up, it was adapted for hauling stuff (plywood boxes instead of chairs, making a long flat platform). Was sold (when new) as equipped with 4x4 control trac, advance trac with RSC, 3.73 axle, HD trailer tow.
This is my first sea faring vehicle (only had smaller sedans until now), I guess it operates fine, one surprise is how slow it is to take off with low throttle input (maybe the torque converter is undersized for a 6k lb vehicle).
I could use some guidance on maintenance and fluids please.
Is Maxlife OK instead of Mercon LV (Mercon LV is kinda pricy right now)? That tiny transmission dipstick next to the exhaust is ridiculous.
What should I use for the transfer case?
For the diffs is GL-5 fine? View attachment 136036
If you are a gear head AT ALL, this one is really cool to see some impressive carnage. It's not that long and you get to see the damage in the first few minutes
Secondly, for every one of these motors where people like to claim "I got 190k" or whatever I promise you if you dropped the pan you'd find pieces of timing chain guides or tensioner seals blown out, etc. Basically, you can't see what's going on inside and no one likes to admit that ignorance is bliss....but the large majority of these are just the walking wounded
REALLY COOL:
I was thinking of using PP 10W-30 from the stash. As it won't be a daily driver (snow and bad roads is the planned use) 5k OCI seems right.I've got a 07 with 260K in our family fleet without any of the "normal" 5.4 3V issues. My advice is to change the oil at no more than 5k intervals. 5w-30 is not a bad choice, either.
As far as the transmission goes, you need to check it hot, but I never had any spill out when opening it cold. My normal change procedure is to suction out the pan when cold and measure it to know how much to put back in. Then after a 20 mile drive, check it hot while idling in park. You'll want some welding gloves to protect yourself from the exhaust.
I have always used regular DexMerc in the transfer case.
The rear calls for synthetic 75w-140 plus LS additive, and the front calls for 75w-90. Mine gets 80w-90 in the front as I have a lot on hand.
If D60 keeps posting those videos I might just sell itYou're kidding me? 4.5k is a steal; here in that Carolina's, I bet that would fetch twice that.
The 5.4 has good torque characteristics. Enjoy your purchase.
I'll be sailing it later today on it's maiden voyage to Tahoe. Will have a better idea of it's power in the mountains.My buddy has a NICE 07 Expedition EL 4x4. He too finds it slow, personally I find it plenty fast enough. I think your experience with it being laggy to accelerate is normal given the power output of the 5.4 and such a heavy vehicle.
Thanks!Very nice. A co worker at a previous job had one that her mom bought new. She ended up getting a newer vehicle and wanted to sell. I asked the wife if she wanted it and she said no so there was that.
I tried the Maxlife rated for LV in my 2009 F150 4x4 w/6 speed auto. Transmission HATED it. Had to do 2 flushes with Mercon LV to get it working like it did before.I could use some guidance on maintenance and fluids please.
Thanks clinebarger!It's probably wise to proactively do a Full Timing Set, Phasers, Oil Pump, And Followers. I'd almost say Valve Springs as well but it really depends on the usage, A overloaded electrical contractor service body F250 IS getting Valve Springs!!!
Not to confuse a worn Follower "unkeepering" a Valve Spring Retainer with Valve Spring breakage caused by sustained high RPM.
Thanks! I think I will use Pennzoil LV in the transmission and transfer case.I tried the Maxlife rated for LV in my 2009 F150 4x4 w/6 speed auto. Transmission HATED it. Had to do 2 flushes with Mercon LV to get it working like it did before.
The 5.4 takes very well to a tune. Ford did not allow full throttle opening until 4500RPM and shifts gears at 5000. Leaving a lot of power on the table. 5star makes a great 87 octane tune.
Do not use 5W-20 oil. The Cam tensioners leak oil and will starve the heads. The oil pump also leaks. There are examples of the 3V engine lasting 350K+, with higher viscosity oil. Use a 10W-30 synthetic as a minimum.
EDIT: The CV and other Ford state vehicles here do not use the 5W-20 oil. If your engine was run on 10-40 or 20-50 as they do here, it will be quite healthy. And will not need chains, phasers or rockers.
