Technically, my sister did. But the car is mine until reconditioning is complete.
It is a 2005 CE with 140K miles. Paid $3K.
My sister lives in the city and needed an inexpensive car for weekend errands. Her plan is to keep the car for a few years and upgrade to something newer.
This Corolla was purchased from a friend of mine. It was their family's spare car for 3.5 years and was no longer needed. They only drove it for 15k miles for the duration of their ownership.
When my friend's family purchased this car in 2018, they had me bring all maintenance up-to-date. I also worked on it a few times over the last few years. According to my records, it received the following work over the last few years:
4/2018, 125K - ATF Flush (AMSOIL Signature Series), Brake Fluid Flush, Spark Plugs, Drive Belt, Coolant Service, Reboot Passenger Side Axle, VCG, Air/Cabin Filters, Timing Chain Tensioner O-Ring, HLR, Intake Manifold Gasket, Radiator Cap and 1 caliper.
8/2018 - Front Pads (OE) and A/M Rotors, Rear Shoes (OE) and A/M drums
3/2019, 132K - A/M Front Lower Control Arms and Alignment
Mechanically, the car is in decent shape. Cosmetically, it is a bit below average, mainly because of the paint that is starting to fail on the roof.
My sister wants this car to be reliable for the next few years. She also plans to take some semi-long trips with it. After inspecting the car and with those goals in mind, she has agreed to move forward with the following items:
- Oil and Filter Change w/HPL Engine Cleaner
- Installed a new Kirkland 35 AGM Battery
- Installed 4 new Michelin Defender T+H tires
- Replaced Engine and Cabin Air Filters
- Replaced Wiper Blades
- Removed the fuel injectors for bench cleaning (clogged injectors are an issue on high-mileage 1ZZ-FE engines)
- Perform a Headlight Restoration
- Perform a Brake Fluid Flush
- Perform a Power Steering Fluid Flush
- Replace a failed Exhaust Donut Gasket (manifold to cat converter connection)
- Clean the Throttle Body and Replace Gasket
- Reseal the Timing Cover due to light seepage at the timing cover to cylinder head "t-joint." Will also replace the crank seal, VCG and timing chain tensioner o-ring in conjunction with the repair.
- Replace the Water Pump and Thermostat using OEM parts
- Replace the Radiator and Radiator Hoses using A/M parts
- Install a Sony XAV-AX150 Stereo and Boyo Back-Up Camera;
@nthach will be helping me with this
- Install a new set of factory carpeted floor mats
Total investment will be $1650.
For $4650 (plus taxes and registration fees), I think this car should serve her well for a few years. When she is done with it, she should still be able to recoup most of her investment.
Here are some pictures of the car after a preliminary wash and vacuum to triage its condition. At some point it will receive a full interior detail:
