Bottle shape and opening size
Originally Posted By: y_p_w
Red Line has this bottle shape that makes it hard to pour because it doesn't vent well.
I don't like the Red Line bottles for gear oil, but for motor oil it's probably my favorite bottle. Very easy to pour accurately or to just drop into a funnel and let it drip dry.
The old Pennzoil 5 quart jugs were splash monsters.
However, I'm really not overly concerned with bottles. Even the worst ones aren't exactly hard to get the oil out of.
Originally Posted By: Flareside302
Is this really a thread?!?????
What hasn't already been covered?
Besides - this is actually a consideration when people use motor oil.
Originally Posted By: aquariuscsm
Holding the 5 quart jug sideways while pouring it makes it come out smoother. Flimsy quart bottles pour out messier than the firm ones also.
I was going to say that...
I get the 5qt jugs for a 4qt fill. The first jug stays with the leftovers, then I pour futur leftovers into that one and throw away the empty. When it reaches 4qts, it's my next oil change. Then I start over.
I never gave it much thought. I like the Pennzoil, Mobil and Amsoil bottles. To me the funnel is the key, not the bottles. After dealing with the oil fill neck on my E-150 for over 26 years I found the best funnel was a homemade job.
This article from back in march on this subject I found really interesting:
Lubes N Greases, March 2013 Page 34
(for some reason when I post a link you get redirected to the current issue)
Pierce it twice, and you get this:
Pretty sure Castrol Edge bottles also have a larger cap that allow for an easier pour as well as Mobil 1.
Originally Posted By: Hyde244
Why don't more oil companies have wide mouth bottles?
Cost of redesigning the bottle.
How many times has Pennzoil redesigned their bottles? They mostly have custom bottles with either a unique shape and/or the name of the company. If they wanted to it would be a trivial cost compared to all their other costs.
Anyone know if it's possible to recycle the bottles if I don't use them to store used oil? I thought it might be possible to wash out the bottles and dump them in the used chemical bottles at that recycling center.
Typically no. You need to check with your specific recycling program. Motor oil is so bad, that a little bit of residual oil ruins the whole batch of plastic or messes up the recycling process. So your good intentions actually could lead to more waste.
Definitely do not try to wash them with water, as then you are just making a mess for your water treatment plant.
I did search the internet and some group was that had a technology to process motor oil-contaminated bottles for recycling, but I don't think it is mainstream.
So this of the reasons to prefer the 5.1 quart jugs is to do your part to reduce waste. (Although it can be said extending your OCI and fully using your oil too).
My recycling program instructed me to just throw out the containers in the garbage, just as they allow me to throw out my shop towels and absorbant that has oil in it too.
What I do to be a good citizen is set the bottles upside down for at least half a day, to get as much of the oil I can out, before tossing it. I just set a bottle in a funnel over one designated collector bottle. This goes for A/T fluid + whatever other petroleum fluid bottles I have that can be safely accepted for recycling. Once in awhile I dump the collector bottle into my drain pan during an oil change to get collected, even if it's basically fresh.
I am fully aware that quick change places, shops, and people needing an emergency quart at a gas stations, will just toss the bottles that probably have half an ounce of oil left in them, but I do my part.
I'm wondering how much oil gets into our sanitary sewers. I've washed oil soaked T-shirts and of course wash my hands after wiping them off. And then there are shop rag services.
My soaked paper towels used to go into the used container cans at this place, but they remodeled and no longer had anything for used containers or oily paper towels. I noted that my county household hazardous waste facility will take nearly anything that doesn't glow from radiation. I might just end up saving the bottles for that.
I agree, the best funnel is made from a discard/used bottle.
I have 2-3 homemade funnels from discarded bottles, one for each size of the oil filler.
yea, the best bet is to contact your local service and ask them what's the best way to dispose of what you have.
