ekpolk,
Is this a "clicker" one or not. Not sure exactly what I am looking at here.
Definitely NOT a clicker. I was able to push it open a little with a little pressure, midway with medium pressure, and all the way with full pressure.quote:
Originally posted by blupupher:
ekpolk,
Well clearly Bosch Premium filters vary by model. Looking inside mine, I saw a somewhat large, robust looking spring. This spring would take the place of that stamped piece of sheet metal in that picture. If you have a preference (surely BITOGers do) then just open the box and look inside the filter!quote:
Originally posted by ekpolk:
Interesting. I guess it's size-by-size with the BPs. Below is a picture of the guts of the Bosch Premium that fits the Nissan/Infiniti VQ35 V-6 (which powers my G35). Unfortunately, I didn't try to get a pic of the other side of the valve, but it is a progressive, spring-loaded mechanism. I know, I've got my pinky stuck in it. . .quote:
Originally posted by Greaser:
Ekpolk...I'm looking at the other new Bosch Premium #3500 that I bought at AutoZone when I was there last,the other one used for a week then removed and dismantled.It's the big Ford oversize that I am using on my Jeep's 4.0L engine (still using the Ford oversize just not Bosch Premiums).On the box it says it has the syn/cellulose "filtech" media.Sorry when I look inside I can see that cockamayme "clicker"Too bad they looked great inside except for the two pieces of sheet metal pressed together with holes in one of them,that is the bypass valve![]()
I guess the morale is that we can generalize by brand, but we need to look at filters on a model by model basis.
There's a substantial difference between the basic Bosch and the "Bosch Premium." I have not cut up your size Bosch Premium, but I have cut up the one that fits the Nissan/Infiniti VQ35DE 3.5L V-6, and its bypass is definitely NOT a clicker type. Are you postive that wasn't a "regular" Bosch? I'm not interested in getting into one of those "I'm right and your not" exchanges, but I do occasionally recommend these to friends, and if some Premiums have a clicker, that would give me something to think about.quote:
May-be you were refering to me.I had a Bosch Premium on for a week in cold weather and it played havoc with my oil pressure warning beeper and the dash warning light at start-up on my 2001 Jeepquote:
Originally posted by 427Z06:
Do the filters have the "clicker" type bypass valve? If memory serves, I remember someone experiencing difficulties with clicker type bypass valves not flowing well enough in extremely cold weather for his application. I'd consider using a filter with a more positive coil spring type action for the colder winter months unless you have an accurate oil pressure gauge where you can monitor what's going on.
.Using the Wix "Sport Truck" filters now, with the baseplate by-pass, and everything went back to normal.After dis-assembly of the Bosch filter the innards looked well made except for the POS "clicker" by-pass valve.Would never put one on another car I service...NO-WAY!![]()
The filtering media is different. I noticed the same thing you did when I cut a bunch of filters open, but I went a step further and found info that proved they were different.quote:
The Bosch Premiums share the exact same "skeletal structure" as the Mobil 1, STP, Supertech, K&N and several others. This is based upon my cutting all of them apart myself with a pipe cutter. I can't speak to the element itself (they all vary a little in color and texture), but the BP is a very stout, well put together product.quote:
Originally posted by Thomas Pyrek:
They are over rated. I'd buy them if they were $3, but not 6. IMO they are slightly below delco, slightly above supertech if they have a real bypass.
Does Champion Labs also produce filters in Mexico?quote:
I agree. Bosch Premiums are good filters. I have dissected one, and have seen for myself that it is a typical Champion Labs product. The element is a slightly different color than the M1, and I can't speak to its performance. I think it's also important to note that apparently, there's a difference between the standard Bosch, which is a mixed bag of products from different places, and the Premiums, which, so far as I've seen, are all Champ Labs products.
I don't know about Bosch, but Purolator Pure Ones can handle long OCIs. One of the best filters on the market.quote:
Originally posted by Islandvic:
I have a Bosch Premium oil Filter for my Modular 4.6 and Vortec 5.3. Free with Auto Zone rebate.
I'm making a switch to Mobil 1 with the infamous "Buy 3 get 3 Free" PP coupons.
I know the evil Orange can is a no-no.
Is Bosch a good filter for extended OCI's with Mobil 1?
The 5.3 is in a '00 Silverado w/ 19k miles. I was changing it only once a year because the "Oil Change Light" never came on and the most it was driven in a year was 6k miles. I want to use M1 and change it when the light comes on.
The 4.6 is in a '01 Grand Marq w/ 26k miles. It gets 5w20 conventional every 5k miles now. I want to use M1 w/ 7500 mile OCI.
Are the Bocsh filters up to this? After the free Bocsh for the Marq is up, I will probably go back to my stock of FL820-S's reserved for my '96 Vic.
Has anyone used Bosch Premiums before?
Who makes them, Champion?
Yes indeed.quote:
Johnquote:
1999 Champion Laboratories breaks ground on a new 200,000 square foot facility in Saltillo, Mexico.
